Hi Everyone,
I have just purchased a Beocenter 7007 and have a few questions.....
The sprung metal container you place the tape in will not lock back into its horizontal position so it is constantly standing at an angle. Is this a common problem and can it be fixed by a non technical person?
I have a remote control that i use with a Beocenter 7000, could this remote be paired with the 7007?
When I first connected the 7007 up there was some but limited sound produced when i played records and the radio (pressing the volume buttons had no effect, it seemed to be at a fixed volume). Now the only time i can get a sound out of it is when i connect my bluetooth Audio receiver via the aux in at the rear of the unit . I vaguely remeber this happening withj my 7000 when i first got it and after pressing some random button it started to operate as normal. Any ideas?
Many thanks,
Miles
