I have 2 pairs of MS150s and I'm considering wiring them in Parallel. Does anyone have experience good or bad with this setup?
https://beocentral.com/beomaster8000
"The colossal Beovox MS 150 was the usual choice, and although it was well matched in most respects, due to its 8 ohm impedance it could not make use of the full output of the amplifier. The Beomaster 8000 was rated at 150W only into 4 ohms, the figure fell to 100W if 8 ohm loudspeakers were used."
thanks
It's a fine line between collecting and hoarding, and I'm always dancing on it. Beomaster 8000 x2, Beocord 8004, Beomaster 6000, Beocord 9000, CDX, Beomaster 6500, Beocord 6500, Beogram 6500 CD, Beogram 6500 Turntable, BeoSound 2300, BeoSound 2000, BeoLab 8000, BeoLab 6000, BeoLab 2 Sub, BeoVox S45.2 x4, BeoVox S75, BeoVox S120, BeoVox M150, BeoVox MS150, RL140, BeoTime, BeoCom 1
The Beomaster 8000 has two sets of speaker outlets so why not just plug one pair into each set of outputs?
No need for any fancy wiring, and the 8000 will cope fine.
Thanks, I wanted to take advantage of the extra power. Also I have a large room and I'm thinking of adding a pair of S120s
