Anyone - which was the last/highest software version of the Beo4/navi?
If possible with details ;-)
Really —— no one???
Hi MM,
Both mine are at SW 8.0, dB 1.2. I have had them about 4 years.
Hope this helps, or prompts others to have a look and give an answer!
Guy
Hi MM
Thanks!
I can then conclude that the 8.0 is the latest.
One of mine has it, the other has the 7.0....
.....so I know the difference.
Just wondered if there was any later version.
