The software for the dual screen experience on the BeoSystem 4 is now available from B&O. You will need specialty Atlona pieces as well as having to contact B&O to have them specifically send you the update to your BeoSystem 4. Apparently it's not a SW that will be rolled out to every machine. All those holding out for dual screen contact your dealer now!!
3rd party products -> HDMI Matrix/Exp./Ext. -> Atlona HDMI Switch/Expander- AT-HD4-V42-B&O
Ah, you know... A little B&O here, a little there
Does any have experience with this setup, and do any use the Beosystem 4 with a non-B&O television?
