Subwoofer connections to Beovision 11
This post has 2 Replies | 2 Followers
thorne
Posts 315
thorne Posted: Fri, May 30 2014 11:51 PM
Hi
i stupidly pressed the sound reset button and so lost all my dealer's adjustments.  I really must leave well enough alone!
Anyway, for speaker connections, I have managed the central speakers, front left and right and rear left and right, but I cannot locate whiicj PL socket has been used for the subwoofer.  Is this random or is ther one which is always used
can't believe I have been so stupid!
Nebelfelsen
Posts 27
It is random...
When configuring the PL sockets in the menu you can hear a sound from each speaker connected to the currently selecte PL socket. Unfortunately the subwoofer sound is very silent. You need a silent environment and your head placed near the subwoofer to hear it.
It might also be a possibility to create a speaker profile where all speakers exept the subwoofer are switched out. an to try the different PC sockets in the configuration menu then one by one. I gues the profile settings need to be updated each time after having changed the PL socket..
thorne
Posts 315
thorne replied on Sat, May 31 2014 8:57 PM
Thanks.  Yes, that was the problem.  I simply couldn't hear the subwoofer.  Ears next to the speaker solved the problem!
Page 1 of 1 (3 items) | RSS
