Hi, I have a Beomaster 2400. After starting up it has noise (bass) which is going away after several minutes (10-20 minutes.). Can someone help? Is the becouse of old capacitors?
Thx, Jiri.
Welcome to Beoworld !
There can be many reasons for humming (if this is the "bass-noise", you experience).Bad capacitors, bad rectifier, wrong wattage lamps...Capacitor and lamp kits exists.
Hi. Thank for fast replay. I did replace the lapms several times. It started to have humming couple months after last replace.
Can you sell me the lapm an capacitor kit?
Hallo Mr. Dillen.
Could you please advice me where should I get the capacitor kit for my Beomaster 2400? Thanks Jiri.
I make the kits.Sens me an email.
Hi. Email me at jiri.*****@instalace-atep.cz . thx J
Email edited (antispam) by moderator
