I would like to clone my Beomaster 5 HDD the easy way.
Just wonder if using EaseUS Todo Backup Free is going to be Ok. I would remove the Beomaster HDD , install it in the computer along with the clone, and then use the software to clone it.
I do not want to mess the original HDD so the reason i need your opinion.
Thanks in advance!
https://archivedforum2.beoworld.org/forums/t/30397.aspx
Thanks!
