Hi All
I was wondering if any body had the volume control drawing for the -2 model as this has 3 ics not one as the 1900 /2400 has ? it dose not appear in the 1900-2 service infomation ?? any help would be great
or where it may be found .....
Regards Ron
(Thread moved to the Private Wanted section).
The new volume control is mentioned somewhere, either in the B&O Tech notes or in the Bomark pages.I will look for it.
OK, found it.That was easy B&O Tech note BM19-24-2Drop me an email and I'll send you something.
Thanks Martin
Thanks for the fast help
That will make life easier
