xml file for Samsung SP-A600B
This post has 0 Replies | 0 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Sun, Jun 1 2014 3:12 PM
Would anyone have an xml file to control the Samsung SP-A600B projector?
Unfortunately, this model is not in the BeoSystem 3 PUC. I'm using the PUC for the A800 model, which also turns on the A600. However, the PUC for the A800 will not turn the A600 off, since the A600 requires you to hit "select" in order to confirm that you want to turn off the projector. It looks like I'll have to do this with the Beo6.
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
