Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Hello Bramble,
There should not normally be any noticeable hum from the motor on the BG8500, I use a BG3500 with the same motor and this is almost silent. Is the noise heard through the speakers, or directly from the motor?
Kind regards, Steve.
Steve.
www.soundsheavenly.com
If the servo belt has been replaced the hum from the motor (actually both motors) will be transferred to thesubchassis, the platter and the record through the servo motor belt.I've seen countless belts that were replaced because they looked lose and the owners wanted to do good, but theyare actually supposed to be a bit on the lose side to avoid the hum transfer (and wedge shaped to prevent the beltfrom coming off).No suppliers I know of (and that includes myself) can supply a suitable replacement belt.Luckily - and unlike the platter belts - all the original servo motor belts I've seen were still fine.If it was replaced and you still have the original belt, I suggest you fit this back.
