remote
Dustin Williams
Kansas City Mo
Posts 3
Dustin Williams Posted: Sun, Jun 22 2014 5:51 PM
I am the proud new owner of a beosound 9000 mklll from Atlantic systems on e-bay. After attempting to buy two other units being misled both times. Anyway my question is will beo 5 remote work with it or stick with the beo 4 remote? Thanks in advance for your help, and thanks to MediaBobNY for the helpful advice!
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 22 2014 5:56 PM
Beo5 will work no problem.
The beo4 is much simpler though.
Dustin Williams
Kansas City Mo
Posts 3
Thank You!
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Jun 23 2014 12:19 AM
As previously mentioned, the beo5 will work just fine with the BS9000 and the design makes for an unusual piece of table furniture, but I would say it is overkill and likely to be more frustrating to use than a beo4 if the BS9000 is the only device you are looking to control. It really comes into it's own when you want more sophisticated control of a number of devices, both B&O and third party, along with macros etc.
I have both and most of the time I will reach for the beo4 (and if I was forced to keep only one remote the beo5 would be the one that goes)
Martin.
Rob - Danish AV
Melbourne
Posts 376
I use a beo5 with my 9000. It was loaded with the beosound 9000 buttons which was handy, as I've never got around trying to program one of these remotes.
a beo4 is much easier to operate, so I always have one nearby in case the fiancé wants to play a cd
Page 1 of 1 (5 items) | RSS
