I presume you daisy-chained the BeoLab 3s downstream of the BeoLab 2 ?
This means you received a new cable for the BeoLab 2?
Or did you reuse the cables you had from the BeoLab 3 to the BeoLab 2 ?
Were there any switch settings on the BeoLab 2 - and what did you set them to ?
BeoNut since '75
Kirky1980:Hi yes got all new cables for a power supply to run the beolab 2 from sounds heavenly and then had new speaker cables to connect from the beolab to the beolab 3's then connected the speakers and I did switch them to left and right on the actual speakers themselves where as I run them in line position befits when I didn't have the beolab 2 and had them connected from an apple airport express
well Steve is very good and very knowledgable
I know I have a mixture of power link cable types from B&O where there are (at least) 3 types (marks I, II, and III) and I know that when I use a Mark I on the wrong speakers I get a continuous buzz even when there is silence.
Did Steve now what configuration you were setting up when he supplied you with the cables ?
I recommend dropping Steve a PM inside Beoworld or emails if you have been corresponding.
I am not familiar with the BL2 and I think that's what's making the difference.
Interesting that a silent Airport Express does not trigger the lights on the BL3s - there must be something in the wiring between the different cables, or how the BL2 behaves - it is quite "old" in comparison to the recent set of speakers so I am not surprised by different behaviours
Kirky1980:Also elephant what did u mean by silent with the apple airport express, as would the airport express turn the speakers on and off as like I said the lights never stayed green when using just the beolab 3's with the airport express
Yes, that is what I meant
I expected the BL3s green lights would go on white the Airport Express became active with an audio signal
When no AirPlay was happening I expect to see silence and hear no green lights (or do I mean vice versa )
