I want to get a Beoplay V1 40....
As front speakers I want to use my Beolab 8000 (connection available ??)
For rear speakers I would need a wireless type to avoid the cables ???
Thank you for suggestions.
Audio: Beocenter 7000 + Beovox S45, Beocenter 9500 + Beogramm 9500 +Beolab 4500 + Beolab 8000, 2x Beolab 3500, Beovox CX50, Beolit 12
Video: Beovision 5500, Beovision MX 6000, Beovision MX 4002, Beocenter 1
Remote controller: Beolink 1000, 2x Beolink 5000, 3x Beo 4
Link room: Beolab active
Hi Hans Jörg,
what - exactly - is your question
If there is a question
My questions are
- are there connections for Beolab 8000 available (should be my front speakers9
- for rear speakers I need a wireless solution
the whole thing should end up in a "surround" setup
The V1-40 has 3 PowerLink ports - each with two outputs.
Means you can connect up to 5 speakers.
If you use the internal speaker(s) as a center, you can built a 5.1 system with ease.
If you need wireless connections (for your rears), you will have to buy the optional IWS Transmitter, since the V1 does not have wireless speaker connection built-in.
If you choose newer (WiSA compatible) speakers for rears, you are good to go then - if you use older BeoLab's, you will have to buy the wireless receivers too.
Gruss MM
BeoNut since '75
