Hi there,
I was wondering if there is a way to connect my Velodyne CHQ 8 active subwoofer to my Beomaster 7000?
Thank you for your help
Seaocean
SEAOCEAN: I was wondering if there is a way to connect my Velodyne CHQ 8 active subwoofer to my Beomaster 7000?
This probably works: http://www.soundsheavenly.co.uk/bando-pltoamp.htm
But email Steve, I'm sure he'll get you the right cable.
/ Johan
Excellent !
Thank you for the tip, will try that
Lionel
