v1 with adobe flash player & mac with hdmi
This post has 16 Replies | 2 Followers
lageir
Posts 10
lageir Posted: Thu, Jul 3 2014 8:11 PM
Having a lot of trouble with the V1.  Coming from using Asian branded TVs I'm flummoxed by B&Os inability to do what I thought was common/basic functions.  Maybe someone on this forum can help.
Tried to stream Wimbledon from the BBC on the V1 using WebMedia.  Can't load Adobe Flash Player & told by B&O that B&O isn't compatible with Flash.  So tried hooking up my MacBook Air via HDMI to the TV.  Some picture lag but watchable.  Then the sound cut out ... then the picture got worse & worse.  So just tried the suggestion here to change picture mode to game and turned of the wlan.  Well that didn't make any difference at all (oh yea, tried different computers and cables and HDMI input jacks.)
So I was wondering:  is there a substitute flash player that I can install on the B&O that will trick the TV into playing Adobe Flash media?
And, is there some fix so that playing content from my MacBook Air to the TV via HDMI cable will actually work?
Thank you.
mawheele
Posts 258
Flash is not always Flash on embedded systems. Its often a cut down version and does not playback consistently off of multi-core processor systems. You'll only really find the full-fat version on current Android devices or PC's - or the developer may use AIR.
I think its fair enough for vendors building systems to not include Flash with HTML5 being common place in most modern sites.
Millemissen
Flensborg, Denmark
Posts 14,680
I wonder which (asian brand or not) tv can show BBC using flash in it's built-in browser.
I have had no problems with connecting a computer to my V1.
And by the way - welcome to Beoworld.
lageir
Posts 10
lageir replied on Thu, Jul 3 2014 8:35 PM
Yea and most sites are flexible, like usdrama.net; says you need Adobe Flash Player but then has a link to click if you don't have Flash (if I remember correctly I think it's called SimpleFlow player or something like that.)  But unfortunately the BBC are real stick-in-the-muds and will only play using Flash ... no built-in alternatives allowed it seems.  Ergo my question about Flash and then my follow on question about HDMI because that work around didn't work either.  Thank you.
lageir
Posts 10
lageir replied on Thu, Jul 3 2014 8:39 PM
We have a Panasonic back home that plays BBC no problem, so seamless in fact I didn't know that it could even be an issue.
And about my computer and V1, are you using a Mac ... maybe that's the problem, maybe B&O doesn't like Macs.  Unfortunately I don't have a PC to test my connection.
And thank you for the welcome.
lageir
Posts 10
And about my computer and V1, are you using a Mac ... maybe that's the problem, maybe B&O doesn't like Macs.  Unfortunately I don't have a PC to test my connection.  And I did ask the dealer here and they said the same thing that you did, never had a problem connecting a computer to a V1.
Millemissen
Flensborg, Denmark
Posts 14,680
On the Pana - do you use a built-in browser? Or an app?
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Jul 4 2014 9:37 AM
Which Mac and which OS version do you use?
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 3:59 PM
My bad.  My wife just reminded me (and in no uncertain terms) that we didn't directly through to the Panasonic.  We played it through a Topfield.  That's why there weren't any issues with Adobe Flash.  Sorry that I got my assertions all wrong.
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 4:01 PM
My bad.  My wife reminded me that we played the BBC live stream through our Topfield ... so not directly into the TV.  Sorry about that bit of misinformation.
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 4:05 PM
I use MacBook Air.  Tried it with OS X 10.7.5, then I upgraded my Mac's software to  OS X 10.9.3.  But both had the same result.  My other Mac uses 10.8.  But again, same result.
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, Jul 4 2014 7:55 PM
Mac mini 2012 had hdmi problems. Since 10.8.5 and FW upgrade hdmi is working properly
hfat
Millemissen
Flensborg, Denmark
Posts 14,680
lageir:
Why not just connect the Topfield to the V1 for that purpose?
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 9:38 PM
Looked into that.  But running a cable from Australia where my Topfield is to Denmark where I'm at now won't work it seemsWink
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 9:40 PM
Thanks for the info.  I guess I don't get why mine doesn't work.  If it was just one computer and/or one cable I'd understand, but I've switched everything around, and it doesn't seem to make a difference.  Maybe I'll take my Mac and cable to the local retailer here and see if they can figure it out.
Millemissen
Flensborg, Denmark
Posts 14,680
lageir:
Try Wifi Whistle
lageir
Posts 10
lageir replied on Fri, Jul 4 2014 9:51 PM
Yea, but there goes my 5.3 GHz speed!
Page 1 of 1 (17 items) | RSS
