Hello!
Just was considering getting a Beoplay V1 - but am I correct that it:
does not have any link connection (netlink)?!
does have the same (modern) chassis like a e.g. Beovision 11?!
thanks, best regards
Elmar
mjmedlo:Incorrect on both. It's the same EXCEPT you must pay for the matrix key
Are you saying the chassis is not the same as the bv11 or not modern , or both?
i understand the V1 chassis is " not proprietary "
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
So there IS a socket for netlink
and what s meant with Matrix?
thanks elmar
Ah, you know... A little B&O here, a little there
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Thanks for sharing your Knowledge; i just want to be Sure that the v1 could be linked to an existing ML/NL Network with the known Converter; as well as connecting it to a nas like it could be done with the bv11; no problem that there is no WISA
thanks best Regards Elmar
Don't worry - it definitely can!
