Noise from beolab3 when switching on-off my BS9000
Mlucarelli
Posts 1
Mlucarelli Posted: Sun, Jul 6 2014 8:03 PM
When I switch on-off my BS9000 or i send a commando from remote control The beolab3 sparks. Simeone fan help me? i nave bene forced to CUT and reconnect a power link cable to one of the speaker could be this the issue?
Playdrv4me
USA
Posts 477
Mlucarelli:
You could try running a single power link cable to one speaker and eliminating the cable that has the splice in it to see if this is the cause of your problem.
I had a BS9000 that would make a "POP" sound in the speakers every time I turned it on and off, or switched inputs. The B&O shop ended up having to service that one after I returned it to the seller.
Page 1 of 1 (2 items) | RSS
