45 on Beogram spindle lifting?
Michael
Atlanta
Posts 98
Michael Posted: Tue, Jul 8 2014 9:21 PM
Just tried an old 45 on my Beogram 6500 and noticed that when the record spins up the plastic 45 spindle lifts the record up for a moment (a few millimeters) before settling just in time for the needle to swing in.  I never noticed this before so I wasn't sure if this was a normal mechanical movement or something needing to be adjusted.  Regardless, it scared the heck out of me as I have a new sapphire cantilever cartridge from Axel and the thought of the arm hitting the edge of the record with the cantilever gives me chills.
Is this normal?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 8 2014 9:30 PM
Perfectly normal. - Both the record lifting and the surprised owner.
Record size is determined by weight.
It can lift a seven inch record but not a twelve inch. That's how it knows which size is on the platter.
Page 1 of 1 (2 items) | RSS
