Beovision 11 sound
This post has 5 Replies | 2 Followers
Peterjs
Posts 3
Peterjs Posted: Mon, Jul 14 2014 9:18 AM
My Beovision 11 is about three months old. Recently, human voice reproduction has become very sharp with any high pitched voice tones accentuated almost with a "hiss" background noise. This particularly happens with female voice tones. I'm sure the B11 didn't do this when I first had it. I've noticed two online updates come in a couple of weeks ago which I think coincide with the clashing noise but I might be wrong. Has anyone any thoughts on this please ? (It's most noticeable with older programmes but it even happens with live news broadcasts)
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Mon, Jul 14 2014 10:01 AM
Check different sources (DVD player?) and tuners if possible and also check all connections. Once you know whether it is a particular tuner problem, or a problem with all sources, contact your dealer.
i haven't noticed any particular sound issues after the last updates with my BV11.
Graham
Peterjs
Posts 3
Peterjs replied on Mon, Jul 14 2014 10:17 AM
Thanks - I'm not using a DVD player. I've checked Sound Modes, default seems to be "Movie". I changed that to "Custom" but it still produces the hissing echo tone. I tried toning treble down and bass up but no difference. All this is when viewing on "Sky" in DTV mode. I haven't tried basic TV mode but will do so in case the problem is Sky related. I don't know how to check if it is a "tuner problem".
vikinger
Posts 5,422
vikinger replied on Mon, Jul 14 2014 5:48 PM
Peterjs:
If you have a Freeview/ terrestrial aerial then checking that should indicate whether it is a tuner or Sky problem rather than elsewhere in the TV. As the TV is only three months old I would get back to your dealer, but only after eliminating the obvious possible external problem sources.
Graham
malcolm welborn
canary islands
Posts 188
I have beovision 11 and sky hd all updates downloaded and no problems whatsoever.
sometimes if weather been stormy sky box can lose some information might be worth trying reload sky software can do this yourself, check with sky which buttons on skybox you press takes about 5 mins
worth a try
.malcolm welborn
Peterjs
Posts 3
Peterjs replied on Tue, Jul 15 2014 7:44 AM
Thanks for that advice
Page 1 of 1 (6 items) | RSS
