BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Did you put the 3,5mm in the dock or in the headphone output?
Try putting it in the headphone socket. The dock-output is a funky piece of work..
I tried it in the head phone socket - did not work either.
Any idea about an App that can play music and has a wake up timer?
leosgonewild:Alarmify
a late reply, I know, but another option would be to use a Beotime which switches the Beolit 12 on with the A.Mem source command at a specific time.
TWG:a late reply, I know, but another option would be to use a Beotime which switches the Beolit 12 on with the A.Mem source command at a specific time.
Does the a.mem command turn on the airplay?
leosgonewild: Does the a.mem command turn on the airplay?
Yes, on the Playmaker it does, so I guessed it'll be the same for the Beolit 12. Maybe some real owner of the Beolit 12 could test and confirm it. :)
A.MEM works to wake up my White Beolit 12.
You can read about this in the FAQ's on the B&O website:
'BeoLit 12' ->
'How do I use a BeoLit 12 with the Beo4'.
