Beocenter 9500 one channel dead
john8
Posts 9
john8 Posted: Wed, Jul 30 2014 1:15 PM
Last time here on the forum I was having problems with the CD player in the 9500, this led me to changing the capacitors using Dillen's kit.
It didn't work for me, so disappointed I put it aside for another day...years later I decided to have another look.
After removing the CD mechanism I noticed the ribbon cable was loose in its socket and all most half out. With nothing else obvious I secured the ribbon cable and replaced the CD mechanism then tried a CD. It played and sounded ok (thanks Dillen) except for one problem, only one channel worked.
A check of my problem revealed;
only one channel CD
only one channel am/fm radio
only one channel using either speaker 1 or 2 outlets
only one channel using the power link
Any clues?
Could have I upset anything when removing/replacing the CD mechanism?
I've been trying to revive this unit on/off for 10 years so its sat idle for a long time
Hope someone can throw some light on my problem
John
Page 1 of 1 (1 items) | RSS
