Help setting beolab 2 with beolab 3's
Kirky1980
Posts 30
Kirky1980 Posted: Wed, Jun 25 2014 5:41 PM
Just connecting up to a non b&o tv and wondering do I set the beolab 3's to line or left and right or doesn't it matter
markiedee
UK
Posts 425
markiedee replied on Wed, Jun 25 2014 8:29 PM
I've read the manual for connecting the beolab3s you should set both of them to line.
Beoplay A2
Playdrv4me
USA
Posts 477
Playdrv4me replied on Wed, Jun 25 2014 10:14 PM
Set them both to "LINE" as the source output jacks will be the ones determining what is "L" and "R" in that case. Powerlink carries both signals, hence the switch.
Kirky1980
Posts 30
Kirky1980 replied on Thu, Jun 26 2014 10:44 AM
Ok thanks I'm running them with left and right at the min and seem fine will line make a difference or not as had these on line when I was using an apple airplay express thing but now beings it's connected via the sub (beolab 2) I thought left and right would be the way to set them, if this is not the case I will change over to line later :)
Kirky1980
Posts 30
Kirky1980 replied on Mon, Jul 28 2014 7:03 AM
Anyone
Page 1 of 1 (5 items) | RSS
