Beo6 bought for BS/BM5
This post has 2 Replies | 2 Followers
Rob
Germany
Posts 28
Rob Posted: Sat, Mar 29 2014 12:59 AM
I absolutely love my B&O stuff (old and new) but sorry I don't know if I'm alone with my Beo6 adventures but this is an absolutely disappointing experience.
- I constantly need to reconfigure the thing to connect 2 way
- Does not connect with spotify (one of the best features of the BS/BM5)
- User unfriendly product (it seems only dealers / programmers can use it properly)
- It has indeed become a paper weight. I have gone back to Beo4
Ps. Do anyone of you know whether radio addresses on BM5 update automatically or do I need to speak to a dealer regarding stations that have changed their addresses.
Will my BS 9000 work 100 percent properly with ML to BM5 in a stand alone set up? Is this tested and approved that everything will work?
Friendly regards from Braunschweig,
Rob
northswede
Stockholm - Sweden
Posts 43
- What do you need to change when you reconfigure your Beo6 form 2-way?
     If it's the BM5 ip-adress that changes, try to configure your router so it won't change.
- I haven't tried this yet, but it's possible to map Spotify to A.MEM and program your Beo6 to use that.
      Will try this weekend, if I find the time...
- Yea, ill guess that's why you should by this as a service from your dealer.
      I know the pain, cause I also want to do it myself :)
- I still think that a well programmed Beo6 are way better then a Beo4, but the Beo4 is easier to get started with.
I haven't started playing with presents and N.RADIO stations yet, but it should be interesting.
Sad to say, but it seems like 3 of my favorite radio stations no longer are available through N.RADIO.
You should be able to use BS/MB5 as a N.RADIO/N.MUSIC source when connected to a BS9000.
I'll think that you have to set the BS9000 as audio master.
Hopefully are my English fairly understandable :)
Barry Santini
New York
Posts 543
Make sure your Beo 6's "server IP" is matched to your BM5's
Page 1 of 1 (3 items) | RSS
