Problem:
Have house masterlinked and have a Playmaker, but no speakers in the garden.
Want to play over Beolit 12 in the garden and over the masterlink in the house simultaneous and in sync.
Solution:
Install Airfoil on your Mac or PC. Startup Spotify and select Playmaker and Beolit as "speakers".
Remotecontrol (change playlists, tracks etc) your Spotify using e.g. Spotremote on your iDevice.
Works great.
A lot of people here may know this already but for new readers it may be useful information.
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
stijndc: I might also reccomend the Iphone/Ipad app called Whaale to stream music from your Idevice directly to multiple Airplay devices. Spotify is unfortunately not supported ...
Thanks - I will test the free testing app from them.
However their UI is skeuomorphism gone mad !
BeoNut since '75
