There are now another three colours for you to choose for your H6, how many of us can match our headphones to our makeup!
http://www.beoplay.com/h6-se
What to choose, if you don't use makeup
... Start using make-up MM
I love the new colours.
Waitin' for it!
The first 'Active Headphone' from B&O - and with AirPlay-support
Mark:I'm grey and slightly wrinkled .....
No ... that's me ...
BeoNut since '75
Millemissen: Waitin' for it! The first 'Active Headphone' from B&O - and with AirPlay-support MM
...and support for DLNA and Spotify Connect
Now, that version should be easy to make.
I'm a fan of the new colours, good play Beoplay
x:________________________
