Just read this review and quite like it, it would be good to hear what others think about it.
heres the link http://www.trustedreviews.com/b-o-avant_TV_review
Beoplay A2
From the article:
B&O TVs have tended to struggle a little where input lag is concerned, compromising their appeal as video gaming monitor.But B&O is adamant that it has sorted this out for the Avant, and our input lag measurements of around 66ms are indeed reasonable (though not spectacular) for a 4K TV.
Am I wrong or "indeed reasonable" is a bit generous for that kind of lag?
Marcello:reasonable (though not spectacular) for a 4K TV.
Marcello:Am I wrong or "indeed reasonable" is a bit generous for that kind of lag?
have a look here
hfat
Chris Townsend:A good review. The sections where it didn't score so highly, will undoubtably be ironed out in Mk2-3.
Well, those areas aren't immediately important Chris - as they rightly say, no/little 4K exists, never mind worrying about HDMI 2.0 or higher standards. When a MK2 ships, we'll no doubt be talking about HDMI 3.0 etc etc. ie. staying on top of forthcoming technology is a huge challenge.
The BBC already claim that HDMI 2.0 won't be good enough to display 4K sport, which they claim will require a minimum of 100fps. HDMI 2.0 can only do 60fps. HDCP 2.2 is forthcoming too, which means current 4K TVs won't be able to display 4K encrypted using this format. It's a bit of a mess really.
He didn't state weather or not he put it in game mode or even monitor mode, and even then by switching off the motion compensation in conjunction with game mode should result in even lower lag I'm sure.
Like I've also stated hd sources don't require noise reduction as it just adds noise to the picture so having that switched off on hd should definitely yield better results.
I would also have sharpness set to its lowest setting also as it does introduce ringing, when i had a home demo of the v1 with a few setting tweaks i was able to get a picture that looked absolutely breathtaking.
