Dear forum members
I'm thinking of exchanging my current BeoVision 6-26 (latest edition with 2 HDMI) against a BeoVision 7-32. The current TV is placed on the floor with the tablestand and has a -9 degree tilt. I would like to buy a BV 7-32 with the low motorstand (4092) and adjust the tilt that the TV can be placed on the floor. Is the tilt of the motorstand adjustable? If someone has this setup, a picture would be nice...
Carlo
Yes the tilt is adjustable manually. I have a BV6-26 on a motorised floor stand that can be adjusted for tilt manually, and you can see that the table stand is the same by looking at page 8-5 of the service manual here
BV6-26 and 7-32 use the same motorised stands.
It would be like a short version of this but you can clearly see the tilt:
http://www.lauritz.com/Item/ItemImage/ItemImagePage.aspx?LanguageId=2&ItemId=2085183&ImageNo=3&ImageCount=6
Thanks for the Links
