Lovely!
I really hope this feature will also come to the Eclipse and the Stage/LG combo :)
MaxH: When playing audio in addition to the track and artist the Harmony also shows which other multi-room speakers are playing
I guess it show the source its picking the sound from, like it does on e.g my Beovision 11.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Interesting.....can you show us more examples?
Do I understand it correct? Does it show what is playing on the Harmony and also what you might Join in to from other speakers? That might be a lot of information, if you have a bigger setup with several on-going sessions in the house.
Thanks for posting ;-)
Millemissen: Does it show what is playing on the Harmony and also what you might Join in to from other speakers?
I´m quite sure it only show the sources it linked to for the sound.
I only have two multi-room products to experiment with but the photo is showing that the Beo2 is the lead speaker.
When the Harmony is the lead speaker it does not show the Beo2 is connected.
Thanks —— that’s a nice feature!
By the way....do you have options for how long this will be displayed?
No. It's the default - about a minute
That is a pity - there should be some options there....time-out duration and off (for those, who do not care).
Seems to be a new icon for multiroom....the circle with the dots and not the two overlappinf squareecks.
May be new icon for the halo... 😁
