My beogram 8000, can be started without record.
When hitting the start/play button the Beogram will start and lower the cartridge onto the platter, even when a record i missing!
Is that normal?
//Bo.A long list...
No, not normal at all.
Antistatic mat on the platter ? (BIG mistake on any Beogram !!)Broken sensorarm lamp (Do you have a spot of light shining down from under the sensorarm ?)Bad sensorarm lamp position.Missing or painted aluminium surround ?Strong ambient light ?Old capacitors ?Cracked solder joints ?
Capacitors and solder joints first, then.Any eventual remaining faults can't be safely diagnosed with the old caps still in circuit whileconnections other places come and go.
Do you have a cap kit for this machine?
Yes. Email me.
