I have a beosound 9000 connected to 2 beolab 1 speakers where each component has its own power cable, so I end up with 3 power sockets plugged into the wall.
I would like to have just one power cable from the wall socket to the beosound and then split it and forward it from there to each of the beolabs.
Is there any off the shelf splitter to achieve this that you know of?
Any other suggestion to simplify this power cabling?
I have as well a Beocenter with 2 beolab 2500 and the speakers have a power input and output connection so you can daisy chain them. I wonder why they don't do that anymore with other beolabs.
