Beosound 3200 and Avant 55
quader
Posts 109
quader Posted: Sat, Sep 20 2014 11:41 AM
Hiya Guys
I had my Beosound connected to the BV7 mk3 previously and I could listen through the Beolab 8000 speakers with the speaker4 option but since the avant has been installed i have lost the use of this function and have been told that I need a cable costing £600 to link it to the avant and the speakers
Has anybody got this setup or could advise
I am currently utilising the Link function on my beo4 remote and listening music on BL3500 speaker
which is not the same
Any help/suggestions would be appreciated
Millemissen
Flensborg, Denmark
Posts 14,680
Hi quader,
you need a NL/ML converter to connect both systems.
Usually this is installed by a B&O technician - unless you are skilled in how MasterLink and NetworkLink works.
Please see: http://www.beoworld.org/beotech/
and/or do a search on the forum for 'NL/ML Converter'.
Feel free to return with specific questions.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Sep 20 2014 1:06 PM
Hi quader,
you'll need an NL/ML converter because the new Avant (and all actual Beovisions) doesn't have Masterlink anymore. The converter has not only to be connected between Avant and BS 3200, but also to a router.
Regards
Räuber
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Sep 20 2014 3:40 PM
You can have a view of whats required in this thread:
http://archivedforum2.beoworld.org/forums/t/11946.aspx
In your case the Beocenter 2 can be changed to BS3200 and the BV11 with BVAvant.
MartinW
Posts 389
MartinW replied on Sat, Sep 20 2014 6:58 PM
The £600 isn't a cable - its an ML/NL converter as described below...
Page 1 of 1 (5 items) | RSS
