Beosound 3200 and AirPlay
This post has 18 Replies | 1 Follower
dmstafford
Posts 6
dmstafford Posted: Fri, Aug 29 2014 7:11 PM
Hi
I have a Beosound 3200 that I would like to stream music to from my iTunes library on my PC / IPads etc using AirPlay - is this possible? If so what equipment would I need and would I still be able to play it via the different B&O speakers I have around the house.
thanks for any help you can give.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Aug 29 2014 10:00 PM
Hi and welcome to BeoWorld.
You could use either an Apple airport express or a B&O Playmaker although the Playmaker is now discontinued you may be able to pick one up at a reduced price from a dealer.
Just connect either to the auxilliary socket on your BeoSound3200.When you use Airplay from your device or iTunes you stream to the AE or Playmaker and it will play through your BeoSound 3200.
Anything you play through that socket will be available on any other loudspeakers connected to your audio master.
Regards
Opman
dmstafford
Posts 6
dmstafford replied on Fri, Aug 29 2014 10:56 PM
Thank you -  I will get a airport express , do I need to get a specific cable for this to work ?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Aug 29 2014 11:05 PM
The cable you need is a 3.5mm jack plug which connects to the Airport Express. The other end needs to be a 5 pin din. (Your BeoSound 3200 auxilliary socket has 7 pins but the extra two are not required). You just need to determine how far away the mains socket is to work out length of cable.
The only setting up required is to register the AE to your network. When you start streaming simply select the AUX function on your BeoSound 3200. This can be done manually on the unit itself or via the Beo4 remote if you have one.
You may need to add the A.AUX command to your Beo4 if it isn't already there. If you need instruction on how to do this just ask, its a simple process.
Regards
Opman
Yendys
Sydney
Posts 312
Yendys replied on Sat, Aug 30 2014 12:37 AM
Opman:
Steve from Sounds Heavenly one of this sites sponsors can supply these cables Smile
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Aug 30 2014 2:26 AM
Be aware that while the Airport Express will work, it's audio quality from its analog outputs is not the best. The Playmaker sounds much better, or you can run the AE digital outs to an outboard DAC and run the analog outputs of that into the Beo. There are a number of inexpensive but good sounding DACs out there that will work.
Jeff
5:8:13
UK
Posts 48
5:8:13 replied on Sat, Aug 30 2014 5:34 AM
I agree; it is certainly worth using an external DAC with AirportExpress: Musicla Fidelity V-Dac or Cambridge Audio DacMagic are both highly regarded and reeckoned to be exceptionally good value for money.  I have both and the sound quality is superb from each. The V-Dac stays on all the time but the DacMagic switches to standby when no digital signal us present.
Hardwriter
Posts 51
I've no experience of using a separate DAC but I do have three Airport Express devices streaming to different B&O systems with BL8000 and old RL speakers. Audio quality seems fine to me. The Airports are also simple to set up and integrate and are robust in operation. I'd recommend you try one before investing in more complex solutions - may be fine for you.
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Mon, Sep 1 2014 10:04 PM
Hardwriter:
Agree!
I have two AE. One connected to my old BeoVision LX5500 via RF modulator and one connected to the stereo in the jacuzzi. I don't use DAC and no needs of getting one. The sound quality is OK for me.
elephant
AU
Posts 8,219
elephant replied on Mon, Sep 1 2014 11:10 PM
AE to BeoMaster 5000 driving 2 x CX100s ... gets lots of use and no complaints
BeoNut since '75
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Sep 2 2014 2:05 PM
As per my original post about AE. I have one connected to the Aux socket of my BeoSound3000 which plays through BeoLab4000 (mark 1) and is also linked to BeoVision7 32.
We don't use the AE a lot but its nice to have when we want to use it. I have no complaints about the sound quality. My advice would be to try it on its own first and then assess if you feel the need to improve the sound quality.
Regards
Opman
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Tue, Sep 2 2014 3:52 PM
I stopped using airport express on my BS9000 via Aux because of the poor sound quality.
Yes it worked, it's nice to have an Idevice in hand and play sound via your B & O speakers but the sound is not good.
I'm talking about Spotify or Itunes here not better quality music if that exists.
And you have to set the volume way up compared to a cd listening.
A DAC or Playmaker must be considered. Just my opinion based on my experience (BS9000 / beolab 8000 and airport express).
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw replied on Wed, Sep 3 2014 11:57 PM
Why did they discontinue the Playmaker?
Sound quality wise is a bluetooth adapter worse than an AE?
Cheers
Nigel
elephant
AU
Posts 8,219
elephant replied on Thu, Sep 4 2014 12:07 AM
h1npw:
..... because they thought the Essence was a superior solution
I think most us would now agree that both have a role (with overlaps)
BeoNut since '75
Yendys
Sydney
Posts 312
Yendys replied on Thu, Sep 4 2014 1:47 AM
elephant:
Agree
Playmaker was a simple product that integrated well with existing ML audio masters to distribute high quality streaming music throughout the home
Millemissen
Flensborg, Denmark
Posts 14,680
Yendys:
elephant:
Agree
+1
I love my Playmaker.
But the Playmaker was marketed as a standalone solution - and ML does not matter for future products.
For the company there was too much overlap.
So discontinuing it was obvious - even if a lot of 'the old costumers' can/could benefit from it.
Hardwriter
Posts 51
Hey Beogreg,
I think you may have had a problem with your AE set up. I use mine on three different systems and volume is the same as other inputs whether I stream from my PC, Mac, iPhone or iPad (usually use iTunes on Mac with lossless and mac quality Spotify from iPad). I just set iDevice/PC output to max and control volume via Beo4.
dmstafford
Posts 6
Thank you  - I have purchased an AE, setup was really simple and the sound is very good. I am just really pleased I can now use my B&O system to stream music to.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Sep 6 2014 10:39 PM
Glad you have found a solution to your streaming question.
Enjoy this new addition to your system. Smile
Opman
Page 1 of 1 (19 items) | RSS
