Correct way to connect BeoLab 2?
RobN
Posts 54
RobN Posted: Sun, Sep 7 2014 10:23 AM
Dear Beoworld community,
After many years collecting B&O I'm very pleased to have purchased a BeoLab 2 woofer to add to my system, but having looked in the user guide I'm not sure how best to connect it. Some advice would be welcome!
I have in the sitting room a BV7-32 which currently drives 2 x BL8000 front speakers and 2 x BL6000 rear speakers. Not only do I watch films via an Apple TV3 connected to the DVI input, I also listen to a lot of music on this system brought in via the MaterLink either from my Mac-Mini/Cambridge DAC Magic/BeoPort or a BS3200 in another room, so ideally want the woofer to work in all circumstance not just when using the Dolby surround sound logic.
How best to connect the BL2? Is it:
1. Via sub-woofer socket on BV7-32? or
2. Via the same power link cables that feed the BL8000s?
Both options are described in the User Manual as valid. Any tips and advice would be appreciated, thanks.
best regards,
Rob
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 7 2014 10:38 AM
Hello Rob,
1. is the way go go because then you will benefit from the sound processor in your Beovision in all circumstances (5.1 sound and stereo).
Regards
Räuber
elephant
AU
Posts 8,219
elephant replied on Sun, Sep 7 2014 10:41 AM
I would connect it to the BV so that the BV is directing the audio depending on the source
If attached via a speaker daisy chain the subwoofer is "invisible" to the BV and you will not get LFE
BeoNut since '75
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Sep 7 2014 1:01 PM
RobN:
Way to go !
RobN
Posts 54
RobN replied on Sun, Sep 7 2014 4:54 PM
Dear Rauber,
Many thanks! Sounds the way to go.
best regards,
Rob
RobN
Posts 54
RobN replied on Sun, Sep 7 2014 4:55 PM
Dear Elpephant,
Many thanks! Sounds the way to go, judging by everyone's response.
best regards,
Rob
RobN
Posts 54
RobN replied on Sun, Sep 7 2014 4:56 PM
Dear Valve1,
Many thanks! Sounds the way to go. Should be enjoying extra bass tines as soon as it arrives :-)
best regards,
Rob
Page 1 of 1 (7 items) | RSS
