Removing V1 Floor Stand
jkhamler
Posts 286
jkhamler Posted: Tue, Sep 9 2014 2:44 PM
Despite my best efforts following the illustration in the manual, I was unable to do anything other than fumbling aimlessly in a small hole with a screwdriver.
Has anybody managed to do this successfully?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Sep 9 2014 9:29 PM
It is difficult if you have never done it before. When you manage to do it the first time you sort of "get the knack".
You need to move the screwdriver up/down to release the catch whilst at the same time (i can't spell Normal 0 false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4
simultaneous) pulling the pole outwards. Once released, only pull a few mm as you then need to do the same at the top/bottom. Once both clips are released, the poles have to be extracted at right angle to the set otherwise they get stuck.
It's not that easy to explain but as I said once you've done it once it seems easier.
Good luck.
Opman
Roger
Norway
Posts 417
Roger replied on Wed, Sep 10 2014 7:58 AM
Just an illustration to go with Opman's recommendation:
jkhamler
Posts 286
jkhamler replied on Wed, Sep 10 2014 9:08 AM
Thanks guys! Yep I've got that picture. In the end I just left it and cut two slots in the box so it could close around the stand et voila, I pulled the TV out at the destination and the stand was already installed.
Page 1 of 1 (4 items) | RSS
