Beocom 2 RJ11 power
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Sat, Sep 20 2014 12:40 PM
Hello everyone. I'm trying to find a UK plug that takes the RJ11 on our Beocom 2. Have looked everywhere [:\'(]
Chris Townsend
Qatar
Posts 3,531
Sorry, this. Want the RJ11 to go to one plug, so it doesn't keep getting knocked out.
w5bno123
London
Posts 578
w5bno123 replied on Sat, Sep 20 2014 12:59 PM
Unfortunaetly the 3 pin UK transformer plug isn't available now so it's not an easy swap over.
The service solution is to have the new cable fitted within the table/wall charger which then terminates into the smaller switch mode power supply. I hope this helps
Chris Townsend
Qatar
Posts 3,531
Thanks. I've ordered one of these so hopefully this will work....
w5bno123
London
Posts 578
w5bno123 replied on Mon, Sep 22 2014 12:20 AM
Hi Chris
Will that adaptor pass 5.6v through it? It looks more like a surge protection plug for a lower voltage phone cable and not mains power
Chris Townsend
Qatar
Posts 3,531
I've been told not. I though it had a uk plug on the other side that would power the RJ11! Cancelled order.
Page 1 of 1 (6 items) | RSS
