BL12.1 How to open the cable Throughput
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Sun, Sep 21 2014 9:00 AM
Dear all,
I have recently bought BL12.1 and want them for wall mounting. There is also a throughput for the cable to run it out on the lower side. But I cannot open this throughput and refused from using too much force. Any suggestions how to open this?
Regards,
Heribert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Sun, Sep 21 2014 1:50 PM
Use your power hand force, to open it. I did Yes - thumbs up
Heribert
Posts 804
Heribert replied on Sun, Sep 21 2014 3:17 PM
ok. Dou you start from the outside or can you push it from the inside? I do not manage to push it out yet.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Mon, Sep 22 2014 1:37 AM
Outside or inside like you want. Don't hesitate to use your power Hand. Don't use a knife.
Page 1 of 1 (4 items) | RSS
