Dear all
i shall shortly be the owner of a BV7-40 MK6 tv and my BV7-32 (Hdmi version) will be used upstairs (directly above it)
if I use a HDMI splitter on the sky and Apple TV downstairs, and use long leads to the 7-32.. Will this give me a better picture then using the RF out on the 7-40? Is it worth it? And will it actually work for sound as long as I use a scart/Hdmi to get the sound out of both the sky and Apple TV ?
i did read somewhere that I the BV7-40 mk6 sound went via Hdmi into Masterlink is this the case ? So taking away the scart socket issue if I want to distribute the rf?
andym
Buying a second ATV would probably come cheaper than buying a long HDMI cable.
i think your right on the second apple tv, for the price its a no brainer I guess, thanks for replys.
