beocenter 9500
This post has 9 Replies | 0 Followers
lotus73jps
Posts 141
lotus73jps Posted: Mon, Sep 22 2014 4:59 PM
hi help just renewed the belts on my 9500  used the replacement guide from martin all whent great put everything back tried tape all I got was click click click no movement  the head did no engage checked the belts again all ok what should I look for
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Sep 22 2014 5:09 PM
Did you just replace the belts or did you also clean and lubricate the mechanisms?
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 22 2014 9:10 PM
Tape loaded ?
Capstans turning ?
lotus73jps
Posts 141
hi dave just seplayed the belts
lotus73jps
Posts 141
hi martin tape loaded yes capstan turning no
Dillen
Posts 13,191
Dillen replied on Tue, Sep 23 2014 7:21 AM
If you rotate the motor by hand (unpowered), does the flywheels rotate in opposite directions ?
lotus73jps
Posts 141
lotus73jps replied on Tue, Sep 23 2014 11:57 AM
hi martin yes both flywheeis rotate in opposite directions
lotus73jps
Posts 141
hi martin im wrong again when I turn the motor by hand no both fly wheeis do not turns sounds like a new motor ?
Dillen
Posts 13,191
Dillen replied on Tue, Sep 23 2014 4:11 PM
A little punctuation would have made that last sentence of yours a much easier read, particularly for a
non-native english person.
And what does "no both fly wheeis do not turns" mean ?
When you rotate the motor pulley by hand, the two flywheels should rotate in opposite directions.
If they dont, you haven't got the belt on correctly.
If you cannot rotate the motor pulley by hand, the motor has seized.
Does the motor rotate when powered on ?
All connectors and plugs correctly seated ?
lotus73jps
Posts 141
lotus73jps replied on Thu, Sep 25 2014 11:56 AM
hi martin I would like to thank you plus other members my 9500 is up and running after renewing the tape belts shaun
Page 1 of 1 (10 items) | RSS
