warranty and wallmount
BHOP240
Posts 7
BHOP240 Posted: Sat, Oct 4 2014 2:07 PM
 I bought a used beosound 9000 is a 200 dollar square trade warranty for 2 years worth it? I bought the wall mount with no screws can anyone tell me w
here i can buy them or whatsize are they
Dave Farr
France
Posts 2,283
Presumably via eBay?  It depends, if it breaks within 2 years then yes it was worth it - depending on what the policy covers.  If it doesn't break within 2 years then it was money wasted apart from peace of mind.  Likely failures are lasers which can be fixed/bought for about what the warranty costs so take your pick.  How old is it.  What MK is it?  Is it a private sale or from a dealer?
As for screws/wall fastenings, that all depends on what your going to fasten it onto - solid brick, concrete, plasterboard (sheetrock), wood panneling? Use the appropriate screw and rawlplugs/expanding bolt fittings as required.  Bear in mind the total weight and make sure the screws/bolts are rated highly enough.
Dave.
Stoobietoo
Exeter, Devon, UK
Posts 692
BHOP240:
I bought the wall mount with no screws can anyone tell me where i can buy them or whatsize are they
Did the wall mount come with any fixings? There is a pack of fixings/spacers that attach the bracket to the BS9000 then you need the screws to attach to the wall.
Take a look here
You'll get the pack from your dealer or could substitute as this guy suggests
Stoobie
Page 1 of 1 (3 items) | RSS
