Beo4 volume button gone !
This post has 5 Replies | 0 Followers
Simonbeo
Posts 1,451
Simonbeo Posted: Fri, Oct 10 2014 8:30 PM
It's happened again. The volume button has fallen off our newest Beo4 and it's a replacement for the original which came with the V1 . Can you buy the button ?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Simonbeo
Posts 1,451
Simonbeo replied on Fri, Oct 10 2014 9:18 PM
Has the navigation edition got a different volume button?
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Oct 11 2014 8:51 AM
The volume button itself on the Nav version is exactly the same design.
I haven't heard of this problem before with the volume button as I thought the rubber there was quite secure.  The buttons usually only deteriorate either over a very long period of time or if people (kids?) pick away at them absent mindedly whilst holding the remote!
You can purchase a Beo4 keypad set and fit is yourself quite easily - the disassembly instructions are in the Beo4 manual on this site.  Should only cost about Eur 20.
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Oct 11 2014 2:20 PM
Thanks Guy. I can't understand why this has happened twice now to this controller when it's our fourth , the fifth when you consider it's a replacement .
Simonbeo
Posts 1,451
But then I could enquire about Remote One controller....
Simonbeo
Posts 1,451
Took the remote into Bromley B&O and Kevin there has ordered a part and will make a warranty claim . That's service for you!
Page 1 of 1 (6 items) | RSS
