Do you think that adding a pair of beolab 12-1 to the Beovision 10-46 will improve sound a lot? or is it better to have them elsewhere?
Thanks!
I hope he will reply if thats the case.
Aussie Michael:Is it Hiort that had the BV10 with BL12s?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Thank you all,
I guess the only way to know is to try before I drill the holes for the wall brackets. I let you know my experience afterwards.
