Hello,
i need help with some trouble shooting.
A while ago i purchased a Beolab 2000 and a Beolink converter to connect them to my Beosound 2300. Actually, due to travel I have not used the setup that much but I have noticed that the light on the Beolab 2000 is yellow although the sound is working "okay". (It should be green right?)
I thought it was because I had used a junction box to get the master link through the wall so I purchased a new master link cable. However, with the new cable the light is still yellow. What could the problem be, remember that I have read somewhere that a yellow light means master link issues.
My setup:
Beosound 2300 - connected with a datalink cable to the datalink connection on a - Beolink converter - connected through the master link cable to a - Beolab 2000
Appreciate any help!
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
I have a beolab 2000 and mine lights up yellow when its switched on but only one of the leds. So i think this is normal!
Cheers Nick
Mine is also yellow and working fine!
Mine looks yellow/green. and has always been that colour. I think it may be because the "green" light is not a definite green. When there is a fault on some Beolab speakers the light goes orange/amber. One of my Beolab Pentas has a fault at the moment and it is a definite orange colour.
Stoobie
Thank you all for the help.
