Hallo together, had a power shut down in the whole house. Now power is back, but Beosound 3000 is only blinking red.
Checked the manual. There I find that I should be asked for PIN _ _ _ _ after a restart.
But this does not appear.
Anybody a clue what I can do?
push f.e. RADIO, PIN........ should appear
reenter your PIN code
Hallo Carolpa thanks that worked. I also turned off the PIN code. Thanks for your reply
