Have anyone tried to use Chome cast with a HDMI-DVI adapter to the BV 7-32?
No, I did not - but you would need a 'box' to split up the HDMI into DVI and analog audio to make it work.
yup
I failed with a Chromecast but succeeded with a Renkforce Renkcast
For details of all hardware used except cables, see my problem description here
I bought an El Cheapo HDMI to RCA powered adapter. It did work, but not ideally.. And I tried to switch resolutions all the time..
Whoops,above should read.. And it tried to switch resolutions.... I can't edit posts on iPad anymore :(
Hi RobB
i just love the Net
So you got sound? And what model was it? A link to the cheapo doodah, I mean...
How often would it switch resolution? Too often to make watching a Netflix film bearable? Or every couple of hours?
Take your time. This ain't urgent...
Mainly changed sizes in the menu. It has sound too, the picture was fine but I think the top and bottom was chopped off.
ill have to find out but it was around $28AU off ebay from China, has a USB plug for power so just needed an iPhone wall plug or something similar
