I recently got the BS5/BM5 combo and I am loving it! However I have a very strange issue with the connection between the set-up and my BeoVision 11 through the ML/NL converter. I have a non-automatic record deck connected to the aux in on the ML/NL converter and everything runs perfectly. The strange thing is that if I accidently tap on the wall where the record player is mounted or even if I tap the wall next to the player where the BS5 is mounted, while I listen to music from the HDD of the BM5, then the BV11 automatically switches to Line in as if I had turned on the record player. As a result the BS5 goes to stand by. The problem is not apparent if I cut the power to the record player. What in the world is wrong?! Maybe there is an automatic channel switch (trigger) in the ML/NL when it receives a sound input. The arm on the record player may detect the sound and transmit it to the ML/NL converter which then switches the channel on the BV11. Does anyone have an idea where I should look for a solution in the set-up.
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
I believe you can adjust the line level sensitivity in the NL converter web page.
Ah, you know... A little B&O here, a little there
Disabling the auto input sensor in the web access did the trick - thank you so much!
