Puc code for Swedish Canal Digital HD box
lonfred
Posts 200
lonfred Posted: Fri, Oct 17 2014 10:13 PM
I have just updated to the latest Canal Digital HD reciever from ADB this box is named TNR-2850 ST and has been used by CD in about two years. I have three boxes connected one each to one BV10-32 one BV6-26 and one BV6-22. I have had my BO technician here to update the PUC software and he tried with all what he found in the library without success. Then the thechnician contacted BO in Struer and got the answer that this box that is the most common one for CD in Sweden does not exist in the puc library but that BO are able to solve it for 500€ and if I send them the box and remote control. It sounds really strange that there is no PUC readdy for one of the most common reciever in Sweden so I wonder if anyone out there is has a puc software for this running and that BO perhaps have given me the wrong answer?
Looking forward to your reply!
Radiomekaniker
Posts 49
There is no need for a new PUC file you can use the one for PVR-101.
lonfred
Posts 200
lonfred replied on Mon, Oct 20 2014 8:24 PM
Thank you very much! I will try that one! Hopefully I have saved 500€ and a complicated processBig Smile
Page 1 of 1 (3 items) | RSS
