Hi there
I thought I'd put this question out to the masses to see what constructive answers I can get back on my quest to get Netflix.
I have a Beovision7 which is connected to Apple TV through my Wi-Fi. So I am able to play my tunes and stuff from my iMac.
Does anyone know how I can connect this to the internet To get Netflix?
Unfortunately I have the 1st gen apple which does not come with Netflix and as this item is no longer supported by Apple I have done a workaround to get Boxee and such like.
Any help would be greatly appreciated.
Connect the Beovision and mac together with a videocable. Then Use netflix through your webbrowser.
It is also possible to use an apple tv, if you want to continue having it wireless.
What os x are you running?
The easy and painless (and cheap) solution is to buy a modern AppleTV.
However, if you have a BV7 without HDMI connections, it won't be as 'painless' as with one with HDMI's.
