BeoMusic App is giving me headache...
This post has 0 Replies | 0 Followers
CB
> You are Here <
Posts 1,762
CB Super Angry [8] Posted: Sun, Oct 26 2014 6:12 PM
Hello B&O fans,
I use the B&O app on an Android (4.4.4 KitKat) tablet to control my BS Essence.
Following a total reset of my device,  I had to re-install all the app.
Since this, the Beomusic app crashes everytime I try to go to the Tune-In panel : impossible to enter my Tune-In account data... Same if I try to open the parameters wheel.
This means also impossible to listen to radios directly from the knob!
Did you ever encounter this problem ?
Thanks.
NB : the BeoSetup app works fine.
Page 1 of 1 (1 items) | RSS
