Hi
I am having trouble with my Apple TV. I want to use the optical out to have the sound via my Beosound 3000 instead of my (non-B&O) TV.
This works fine for audio, eg. streaming Spotify --> ATV --> DAC --> BS3000 works perfectly.
For movies, I use the following set-up:
NAS --> 8Player on ipad --> ATV --> DAC --> BS3000.
I only have sound when using the "ipad mirroring" on. When simply streaming to ATV without the mirroring option on, I don't have any sound.
Any thoughts on how to resolve this?
Take a look at the Digital Output in the settings in Apple TV - try auto or 16bit - it may not be compatible with your DAC or if it is set to auto set it to 16bit
I would say yes because in mirrow it's only stereo.
what you can try is to stream music to your apple tv, and a video from youtube if the sound is there then it's the isue with the 5.1
