I have a Beomaster 7000 that will simply not respond to the remote. It will not turn on or off or switch sources. I have tried a working Beo4 and 3 working Beolink 1000's. I know they work because they control my AV7000 just fine., Anyway, I also have this same problem with a Beomaster 5500 that is sitting in the closet.
As always, I appreciate the help of the forum members.
If the little red light is on the front panel when you connect the mains it is odds on that the BC is in "option 0".
When the red light is on press SOUND 1 STORE on your Beolink 1000.
It should be OK now.
Iif it does it again when the mains is disconnected then the lithium cell is jiggered and needs replacing.
Regards Graham
